跳转到主内容
型号A1288,闪存容量:8、16及32GB
iPod not charging from wall plugs but from every thing else?
My iPod Touch 2nd Gen no longer can charge from wall chargers but it can charge from everything else dock, computer and car charger.
I think there is something wrong inside the iPod where the dock connector is.
Any idea what could be causing the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Patrick Mifsud, I would think that the error is not your iPod but your wall charger. I checked on pinouts.ru and I do not see that the pins that are responsible for charging change with each adapter. It appears the pins are the same for anything that charges your iPod, hence; check the wall charger and the cable going to your ipod. Good luck to you and let us know how it went.
这个答案有帮助吗?
得分 2
8条评论:
I have checked the wall charges they working but my iPod touch does not charge from them still. I think there is something wrong internally.
完成的
Patrick, if it would be your iPod touch, it would not charge from anything. The dock connector gets a charge to the same contacts regardless is you charge it from the USB,a dock or a wall charger.
完成的
Is it posible that some how i fried something on the inside like a resistor or regulator?
完成的
I do not think so. Having checked the pinout once more I do not see that it makes a difference from where the iPod gets its power for as long as it has sufficient amperage. I still believe that this is not an iPod problem but an AC charger problem. The same topic is being discussed on here http://forums.macrumors.com/showthread.p... go check it out.
完成的
I have checked the charges but nothing is wrong and the cabels are fine. I have no idea what the problrm is.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Patrick Mifsud 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 5,070
