跳转到主内容
加入维修社区 - 创建账户
新 Nintendo 3DS 是 3DS 产品线中第一款大幅更新的迭代设备。在日本于2014年10月发布,北美市场于2015年9月发布。2015款 3DS 改进 3D 显示性能,全新 C 摇杆,内置 amiibo 读写功能,以及全新的4肩键配置。
How to fix my R button?
My R button went from sometimes not responding to just being useless, I want to repair it myself and opening the console is not that hard, you just got to be careful, but I haven't seen any tutorial to any fix for shoulder buttons and I want to ask anyone here if they can help please.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
As far as I know it shouldn't be difficult to replace the shoulder button yourself. You just need to follow the steps found here: Nintendo 3DS 2015 Motherboard Replacement until Step 9 (or until you separate the lower case from the rest of the device. As you can see the trigger buttons are not like on the DS Lites of old, but rather screwed into the casing. Remove the problem button assembly, you could try visually inspecting it to see if there is anything obvious wrong with it at first glace, put your console back together and give it a shot.
If the problem persists, you should look into getting a new button assembly, you should find those for instance on Aliexpress.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Juan Carlos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 6,346
