跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
What is wrong with my battery?
My battery randomly drains from time to time (like 1% every 30 seconds) and works perfectly sometimes. A 10 min youtube vid sometimes takes 2% battery while other times takes 10%.
-phone works and functions perfectly
-battery has been calibrated
-charging times are normal ~ 2 hours for full charge
-battery has been recently replaced, perfect wear level on batterylife
-not any apps or anything (checked THOROUGHLY)
-low power mode doesnt change anything
-drains 10% to 30% overnight (~8 hours) no use, no notifications popping up
-turned phone off, waited a few minutes, then plugged charger. It turned on. (if this means anything)
Is this because of a bad u2 ic chip?
Or a bad replacement battery?
Or anything else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Are you synced with a Mac or PC when you hook up? Diagnostic tools are different.
完成的
What do u mean?
完成的
添加一条评论
3个答案
已选择的解决方案
It sounds like you are on the right track in your diagnosing...but to be sure, check battery replacement is good. Measure the charging circuit to very it is indeed putting out proper voltage to charge. It could be battery, Charging port or the charging IC (s), U2 (Tristar) or Tigress.
Update (08/09/2017)
I'm sorry, I meant you could measure the voltage using a multimeter where the battery plugs in.
Here is a youtube video link that may help.
https://youtu.be/6nrw-Q8-NI8
这个答案有帮助吗?
得分 2
1条评论:
Ok thank you! Im confused, what do you mean by the charging circuit?
完成的
添加一条评论
最有帮助的答案
I would recommend trying a new battery, if you continue to have problems then it's probably the u2 ic chip or a software issue rather than hardware. It's fairly common for batteries to be defective occasionally.
这个答案有帮助吗?
得分 2
添加一条评论
Sorry, I tried ading a link but it was removed as spam, so I'll try to ad it here to test charging circuit I answered earlier
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Lieu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 390
