跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
After ribbon replacements, phone still not working
Ok, my brother dropped his phone in water. After getting heated as to why it wouldnt work, he basically ripped it apart tearing several ribbons. (heated temper). He sent it to me to sell it for him, but I found this site first. I ended up replacing all the bad ribbons, and put everything back together piece by piece. Now that its all back together correctly, it still wont power on. Any tips?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
try replacing the battery, they often short with water damage. try that and then go from there. once the battery is replaced see if the display works, if not then try itunes to see if it is recognised...
这个答案有帮助吗?
得分 2
3条评论:
Ok, I replaced the battery now, put all pieces back together. The phone still wont power on. If its a motherboard issue im hosed. Anymore tips? I thought about going through it and spraying contact cleaner all over it, but not sure if thats gonna solve anything.
完成的
Dinobot, I'd stay away from contact cleaner. All you really would have to do is clean the logic board with alcohol and a soft brush. Check all connections and make sure you have no corrosion on it. I am sure you also checked all your ribbon cables etc. I also suppose that reset/restore etc are not responsive. I would think that you have a logic board that got shurtened out by the original submersion. You may just have to get a replacement for that. Just my 2 cents and the real expert on this is pollytintop
完成的
Before declaring the phone dead.... Have you tried iTunes to see if it recognises the phone?
Things to replace/check before declaration of death are.... Battery, dock and LCD. I'm not sure that simply replacing the ribbons will diagnose or fix a faulty display.
If you have another iPhone and feel confident you could swap the logic boards to see faults
完成的
添加一条评论
Chek if the battery is well connected to the board, if everithing is ok then you¡r iPhone must to be death :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dinobot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 680
