跳转到主内容
Repair guides and support for your Samsung TV.
2614 个问题 查看全部
My tv turns on but when screen comes on the words are doubled.
The words are like a split image. Like this- Weak or NO Signal
Weak or No Signal
Except that the bottom words are lighter and they are flickering. Where would the problem be located? When I go to the menu the pictures are doubled also.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@neil56 what is the exact model number of your TV?
完成的
添加一条评论
2个答案
最有帮助的答案
@neil56 if it looks something like this
Then it is a GATE TAB Bond failure on your panel. Check on the thin ribbon cables that enter the side of the panel. See if you find some corrosion or other damages to it. Sometimes a bit of pressure on those cables (try the top left side of the panel) can help to correct it for some time (fixed one with duct tape :-)
Here is a great image of the TAB's
from here.
The only permanent fix is replacing the panel. If unsure where to look and what to check, post some good images of your panel etc. with your question. Use this guide for that.
这个答案有帮助吗?
得分 3
添加一条评论
That is a symptom of a bad LCD screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neil Long 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 268
