跳转到主内容
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 个问题 查看全部
Replacing motherboard -will xp operate automatically?
Hi -- I need to replace the motherboard on my ZG5 (too many problems trying to install replacement power jacks). Should the XP operating system work automatically once I put everything back together (i.e.--does it exist completely on the hard drive?) or am I going to have to re-install XP. This computer didn't come with any restore discs, etc.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks --I hope that's the case --I'll let you know how it works out!
完成的
添加一条评论
1个答案
已选择的解决方案
You may have a partition on the HDD that has your XP on there. I have had it on my Dell and Toshiba. Anyhow, when I replace my motherboards I usually end up having to install the drivers for that particular motherboard since they will be different and windows will tell you that it has found new hardware. So make sure you have a disk with all the drivers for your new motherboard and follow the install instructions. At this point you really have no other option than to give it a go or purchase a new copy of xp as well as having a disk with all the drivers for your Acer. I hope this makes sense and it is really not all that bad and complicated. Good luck and let us know.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brian Mott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 927
