跳转到主内容
The Samsung Captivate is a USA-exclusive flagship Android phone in the Galaxy S class of devices, released by Samsung in March 2010 for use on the AT&T network. Identifiable by model number SGH-I897.
13 个问题 查看全部
Micro USB port not connecting to my PC.
The pins in my Samsung Captivate have bent inside the port and broken off from normal use. Now the phone charges slowly and isn't recognized by my PC at all. Therefore, I can no longer transfer media, backup, or enter download mode to flash with Odin. Any information or help with this would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
http://www.globaldirectparts.com/Samsung... has most of the parts that you might need and I would think that your problems are related to the bend/broken pins and should be resolved when you replace the broken porT and here is more info about your phone and its issues. Good luck
这个答案有帮助吗?
得分 0
添加一条评论
Adding to the previous answer, you can see the Samsung Captivate Motherboard Replacement guide to learn how to disassemble the phone down to the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
With most of the new Samsung USB ports they look much different than the others and have 7 pins as apposed to 5 which is another factor. To throw a wrench into the mix there are now many sellers offering these on eBay but there is a standard mount style and reverse meaning it will be flipped over with the side with more surface area against the logic board. I don't know why they don't seem to catch on but MOST of the sellers on eBay have it wrong. Here is a seller I KNOW and have dealt with before and I can tell you for sure this link is to the correct one on eBay. Keep in mind even if the picture is correct they might just be using a picture from the other along with the wrong info. If you need a port for a captivate and any tools like Torx kits here is the link you want. The item # is USB813 BTW.
http://www.ebay.com/itm/Micro-USB-Chargi...
Hope this helps somebody.
Richard
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Spencer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 4,606
