跳转到主内容
加入维修社区 - 创建账户
HP Pavilion x360 15-bk020wm 是一款配备触摸屏的 15.6 英寸笔记本电脑。它搭载 Windows 10 操作系统、英特尔酷睿 i5-6200U 处理器、8GB 内存和 1TB 5400rpm 硬盘。
Why is my computer slow?
The computer is running slow when it is turned on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
replace the 5400rpm traditional harddrive with a sata III 2.5" solid state drive
这个答案有帮助吗?
得分 1
1条评论:
This is likely not the only cause but will make a huge difference.
完成的
添加一条评论
More info? Is the computer particularly hot? Is the fan working correctly? Model? What sort of tasks are you trying to do on it and what is your chipset? Are you running a power saving mode of some sort? How old is the machine? What is the OS?
这个答案有帮助吗?
得分 0
1条评论:
go into power management and change to balanced
完成的
添加一条评论
There are many reason to why your computer could be running slow but here are a couple of the most common options. There may not be enough space in the hard drive so erase unwanted material or replace with a larger hard drive. It could also be the size of the RAMS and you will need to reduce the number of programs running at the same time. It could also be your operating system, so check and see if it is running on Windows 10 and instead install Windows 7 which is much faster.
这个答案有帮助吗?
得分 0
添加一条评论
If your computer is only slow at startup it is likely that there are a lot of applications and/or services set to run on windows start up.
This is likely the result of installing applications on your PC/laptop.
When my PC is slow to start, I check the following.
1) Under “Control Panel\All Control Panel Items\Programs and Features” were there any new programs installed around the time the slowdown started? If so I uninstall them and see if that cleared it up.
2) Verify that the Startup folder only contains apps I want to start when I boot windows.
3) Use regedit.exe to verify the following registry keys only contain applications I want to start when windows starts. (Exercise caution here, remove the wrong things and your PC may not work as expected)
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run
4) If I still have a problem I sort through my windows services to see if there are any set to "automatic" that I don't want running.
This is an effective way to remove bloatware and improve the speed of your PC.
That said if you bought your PC within the last ten years or so and you really want your PC to boot faster. Consider replacing your system hard drive with an SSD. The difference in speed is ridiculous even on a “slower” PC and the price has really come down.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Meshayla Block 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 2,184
