跳转到主内容
I lost files when I do my pc factory reset how can find them?
After factory reset I didnt find my files
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Stop using the computer, turn it off. Take it to a computer shop so they can use recovery software to get whatever is left..
If your data you lost is important there is no simple way to get it back. Software recovery is never 100%
这个答案有帮助吗?
得分 2
添加一条评论
@yohannes61 what type of files? It is possible that they got overwritten when you performed the factory reset. You need to tell us what OS you are using and what type of files you are looking for. Also tell us what you have tried to recover those files.
这个答案有帮助吗?
得分 2
添加一条评论
If you did a factory reset stop using the computer and pull the hard drive . Place it in an external enclosure or use some other method of connecting it. Connect to another computer and us a program called Zar X then run a drive recovery . You will end up with a lot of raw data but you will be able to recover what hasn't already been overwritten . You will require a large amount of storage as you will be recovering as much data as was originally on the drive including things you deleted in the past that weren't overwritten . hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
Try with Recuva free software, it worked to me a couple times when i had to find an erased file, are the same guys who use CCleaner to fix registry issues on windows, also cleans innecessary files, freeing lots of space. https://www.piriform.com/recuva
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tekeste 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 72
