跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
opened dryer while running without hitting pause button
My mom opened the dryer while it was running without hitting the pause/cancel button now dryer wont turn on, the lights are flashing & its keeps beeping. I tried holding down both the start & off buttons but beeping still wont turn off & dryer wont turn on. How do I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@hawild unplug the unit from the outlet and let it sit for awhile. Then try again. Keeping it unplugged should reset it. you can also try to hold the "Drain/Spin" button and the "Start (Press & Hold)" button at the same time for no less than 3 seconds
这个答案有帮助吗?
得分 1
2条评论:
We tried that but it didn't work. Thanks
完成的
Okay so there is no change when you unplug it?
完成的
添加一条评论
My dryer may be different from yours but i held the cancel button down for about 10 seconds. after that, the start button worked normally
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Heidi Wild 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,221
