跳转到主内容
加入维修社区 - 创建账户
Released on June 23, 1996, Model NUS-001, the N64 is Nintendo's first, and, up until the release of the Switch, only 64-bit gaming console (The GameCube, Wii, and Wii U could perform 64-bit floating-point calculations, but this is not true 64-bit architecture).
It powers on but won`t work on my tv
I have tried it on all of the tv s in my house and I can`t get it to work. It works at my in-laws and it worked on a tv in my shop. That tv is now in my house and it does`nt work on it.I brought home a super nes and it works fine. Could my sattilite interfear? I`ve tried it on HD tvs and standard and the only thing thats changed on the one tv is being hooked up to my satilite.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
Your 64 is run on the PAL (analogue ) factory set yo channel frequency 36, try tuning with the TV aerial NOT plugged in you may have co-channeling.
这个答案有帮助吗?
得分 1
添加一条评论
If the only difference is the satellite then why do not just disconnect everything else and hook the 64 up directly to your TV See if it works and then try to connect the other pieces back to see what interferes.
这个答案有帮助吗?
得分 0
1条评论:
I agree with OldTurkey03. If you have confirmed that the N64 actually works then it has to do with TV itself and the way you go about hooking it up.
完成的
添加一条评论
U need a tv that's old as !@#$. It's sad but true. If that's not gonna work u could try modding it with a guide found everywhere on google.
这个答案有帮助吗?
得分 0
3条评论:
Not true. N64 works fine (with composite video) on my brand new HDTV. And composite video looks fine, i dont know why everyone says its so bad, its just fine.
完成的
You have a different tv than the rest of us, bud. I try these consoles out on the regular and it's rare I get one that reads on a newer tv, the situation being that the source detects the output but will not display.
完成的
@shaman32 what input does ur n64 work on?
完成的
添加一条评论
Could be the RF modulator has had its day that’s the part that that gives out signal that the tv picks up. Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard Colquitt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 7,894
