跳转到主内容
加入维修社区 - 创建账户
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
How to replace the glass only?
Has anyone tried this? Found a 25 dollar 1st gen in good condition on eBay and I would like to get it but it has a cracked glass. LCD is fine. Does it have LOCA? It is like the 3G/3GS screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Due to the design of the iPhone, the glass cannot be replaced seperately from the LCD panel. The glass and LCD are fused together during manufacturing and cannot be separated. Both the glass and LCD panel must be replaced as a unit.
更换第一代iPhone 的屏幕总成
这个答案有帮助吗?
得分 3
3条评论:
Could I remove the dock connector?
完成的
@mayer is correct. The average user can't replace the glass on it's own. This is not a DIY job.
It can be done with the right equipment, new glass, a UV light and LOCA glue but it's probably something you aren't capable of doing.
完成的
I have done LOCA replacements before, they were not perfect but they looked a lot better (a spec of dust got in the screen) Also, I just bought the phone.
完成的
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 188
