跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Pressure/ Stress marks on replacement screen
I just changed the screen on my phone because it was cracked. With the replacement screen connected to the phone but not inserted in it the screen is perfectly fine. But when I insert the screen in the phone it has a pressure/ stress mark in the upper right corner of the phone. I've tried taking the screen out and reasserting plenty of time and it is still doing the same thing. Any help would be appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I’ve recently dropped my phone and it cracked pretty bad. There are a few small yellow dots near the badly cracked areas but the still works. I’m getting my screen fixed and I’m wondering if the yellow dots go away after.
完成的
My iPhone 6s plus, I was wondering what was this blue mark on the screen, I just left it beside me, without giving any pressure, how do I fix it? Can I fix it with replacing the screen, or will it remain actually permanent? It’s like a smokey blue color
完成的
添加一条评论
2个答案
已选择的解决方案
The upper right hand corner has the rear camera and screen bracket. If they are not installed correctly, then they will apply pressure on the LCD and cause stress marks. I would double check the camera and bracket using this guide.
It is also possible that the replacement screen is causing the issue. Some inexpensive screens are not well assembled or have thicker frames and poor tolerances. The other thing to check is the Front Camera and Sensors. If you moved them over from your original screen, you may have incorrectly assembled it.
iPhone 6 Plus 前置摄像头和传感器组件图片
指南
iPhone 6 Plus前置摄像头和传感器组件更换
难度:
中等
1 - 2 hours
iPhone 6 Plus 后置摄像头图片
指南
iPhone 6 Plus 后置摄像头更换
难度:
中等
20 minutes - 1 hour
这个答案有帮助吗?
得分 3
添加一条评论
Make sure the scree flex cable not pressed by the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ladarius Honorable 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 6,273
