跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
7200 RPM drives in mid-2011 iMac
Would it be safe to upgrade to the 7200 RPM drive in this iMac or would overheating be an issue?
And would it require a temp sensor to make it work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Here's what you need to install any third party drive.
https://eshop.macsales.com/item/OWC/DIDI...
For better performance go with a SSHD.
https://www.newegg.com/Product/Product.a...
Without the OWC sensor the fans will run at full blast.
这个答案有帮助吗?
得分 3
3条评论:
@pccheese Corporal George Would like care to work with this the new recruit Ethan? It's Tuesday and I generally like to give them till Friday before evisceration. He may show some promise as he deleted another answer, so it appears he may be teachable. Maybe you can show him the ropes. First lets get him down to just one account.
完成的
Yes, sir. I wrote a comment asking him to contact ifixit about his accounts.
完成的
@pccheese Well done.
完成的
添加一条评论
An upgrade to a 7200 RPM drive would be no-problem, Just be sure to purchase a fan control software because apple's Hard Drives have special temperature probes.**iMac因特尔 21.5" EMC 2428 硬盘更换
这个答案有帮助吗?
得分 -1
2条评论:
@ethanstiles1 You've never done this on this model have you? Were the drives Apple priority? If he changes brands will the old sensor work. If he gets run away fan issues what should he do? Would an SSHD serve him better? Frankly your answer will lead to a lot of possible issues.
完成的
@mayer sorry, you would need fan control software because this model has an internal temperature probe in the hdd not a external sensor, my bad
完成的
添加一条评论
添加你的答案
lcarsner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 202
