此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
升级你的硬盘来扩容储存空间。
本指南还包含将 iMac 硬盘升级为 SSD 的步骤。其中介绍了如何安装 SSD 的温度传感器,以确保 Mac 风扇能以正确的速度运行。
在对 iMac 进行任何操作之前: 拔下电脑电源,并按压电源按钮十秒钟,以释放电源供应器电容器中的电荷。
请务必小心,不要触碰电源供应器背面的电容器引脚或任何裸露的焊点。
你所需要的
按照本指南相反步骤来重新组装设备。
326等其他人完成本指南。
由衷感谢以下译者:
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
82指南评论
Hi guys, the tools arrived today and I did already chage the default harddisk against the WD Velociraptor 500GB. For now everything is working fine. The iMac is in the middle of restoring the time maschine backup. Everything worked out as described. Excellent! I was just a little surprised by the magnetic forces which one needs to overcome gently...
Is there a temp sensor that monitors the HD? I did the upgrade but now my fan is always on. I must've done something wrong.
Did you use the same brand hard drive? Did check the instructions about cable orientation on the hard drive? Did you double check the LCD thermal sensor cable?
Scott Dingle - 回复 分享
Take a glance at this page for full explanations:
http://www.hddfancontrol.com/imac-hard-d...
I had the same issue here (after replacing the original HDD by a 1TB WB Caviar Blue) and it has been fixed by this utility.
HTH,
In response to the software, that does work, however, it can be taken care of hardware wise if our recommendations are followed.
