跳转到主内容
Ordered Verizon specific charge port, phone will not recognize
Ordered G5 battery port specific to phone.
Phone give message: "the module you've attached doesn't work with this phone or isn't inserted correctly. Please use a Verizon-compatible module..."
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Where did you order from?
These things are easily mixed up.
I suggest speaking with the seller to get a return or exchange.
这个答案有帮助吗?
得分 0
1条评论:
I bought a charging port assembly from iFixit and got the same message.
完成的
添加一条评论
I bought a charging port from a different supplier, installed it and got this message. Put the original back it - works.
Update (07/07/2020)
It was most definitely a bad part, FYI! Problem solved with a charging port bought from a different supplier.
I had tried 2 different ones from same supplier and had same issue. They must’ve had a bad batch.
A good reminder to think about the parts you’re using, it could always be that!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vanceakins75 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 401
