跳转到主内容
A 17.3” gaming laptop by Asus.
6 个问题 查看全部
Headsets only work for 5 seconds at a time
My headset(s) don't work. Sometimes they work for like 2-6 seconds. I've opened sound in the control panel but the headset isn't there. It only shows up sometimes when the audio is working. Right now it's just going off and on all the time. Yesterday it worked if i didn't move but now it's alot worse. I've also checked for viruses and there was nothing to be found. Switching to another USB didn't work either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@nikolaio this "it worked if i didn't move" makes me suggest that you try another headset first to make sure that it is not your set that is broken. Then make sure that you have the proper audio driver for your Asus installed.
这个答案有帮助吗?
得分 0
2条评论:
No other headsets worked either, they were not even registered. When it comes to "make sure your audio driver is installed" i dont know what that means. I should probably say that all the other headsets i tried which didn't work weren't usb headsets which mine is.
完成的
@nikolaio okay comparing USB and non-USB headsets to diagnose a fault is kind of comparing Apples to Oranges:-)
What OS do you have and have you checked the audio drivers in system settings?
完成的
添加一条评论
添加你的答案
nikolai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 94
