跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
2nd Generation iPod Touch water damage, 8-9 years ago
As a kid (8 years old), I was stupid with electronic devices. The iPod 2nd generation was one that I was stupid with. I did not make a good decision. I cleaned my iPod touch 2nd generation screen with water. Yes, I did do that. I used to rinse it under running faucet water a lot to clean the screen. Until one time, I did it and my screen started glitching. I am assuming the water went in through the home button because after I rinsed it I used to wipe it off with a paper towel immediately. I am now 17 years old now, it was about 8-9 years ago. I THINK I turned it off, but I did leave it in the sun. Does anyone think it will work? By the way, my dad and my sister found it yesterday when clearing out junk.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
wow, dude, you have big problem
完成的
添加一条评论
1个答案
已选择的解决方案
Jojo possibly but you will have to do a few things first. You do want to go ahead and disassemble it by using this guide. Once upon, reevaluate the damage. I would expect plenty of corrosion on the board, connectors as well as flex cables. You can try and clean all of this the same way as shown in this guide. I was written for an iPhone but all the points are still pertinent to your iPod as well. Once it is cleaned, assemble it with a new battery (do not reuse your old one). Only after all these step will you be in a position to properly troubleshoot your iPod. It might also help if you post some good images of what your iPods logic board looks like when you disassemble it. Post some images with your question by using this guide.
iPod Touch 2nd Generation Logic Board图片
指南
iPod Touch 2nd Generation Logic Board Replacement
难度:
困难
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jojo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 55
