跳转到主内容
加入维修社区 - 创建账户
苹果的第四代无线键盘。发布于2015年10月。型号A1644。
Replacing the Key Caps in the Correct Way
I'm wondering if there is a clear and precise way to replace the key caps on this keyboard. I've removed the space bar, one of the enter keys, and tab - successfully replaced them all but there is a very obvious lack of bounce that comes with the pressing of the other keys. Wondering if there's an illustrated guide or just general advice.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi luke.
The short answer, is that there may be an issue with your scissor clip, or the silicone dome underneath.
The longer answer...
All clips are designed to slide on one side, and will clip on the other.
On the Magic keyboard, they are upside-down when comparing with most earlier models. So when removing the key, to prevent any damage to the scissor clip pegs, (when removing the alphanumeric keys) you will need to pull the bottom side of the key up before the top.
As an example, here is a guide for an earlier version of keycap, so you have to be aware that your key is upside down in comparison, but this illustration will help understand how the key works:
http://www.thebookyard.com/images/manual...
Have a close look at the scissor clip underneath and make sure that the top 2 corners have the pegs intact still, and the bottom edge has 2 square holes for the key to clip onto. Then make sure the rubber dome (known as the silicone dome) in the centre is not damaged and inverts properly.
Then inspect the underside of the keycap to make sure the plastic pegs and clips are not bent or damaged.
The larger keys are slightly more complicated, as they often have retaining bars (metal brackets) that help keep the key straight when being pressed from different angles, but the alignment of these is crucial to getting a good response from it.
The space bar has multiple scissor clips, but only one silicone dome, so when resetting, the process is similar, you just have to be very carful when lifting it that you dont damage the pegs on the clips.
Here is an image of an intact clip and keycap for the magic keyboard. Align the orange section first, making sure the scissor clip tabs are under the loops, then press the bottom of the key (the red marked pegs) until it clicks into place.
Hopefully this will help.
这个答案有帮助吗?
得分 10
2条评论:
This really helped me! Thanks!. One thing I would add in addition to that manual is the new scissor clip mechanism should also be detached from the bottom first (instead of pushing in from the side as indicated in the linked manual).
由完成的
Thank you very very much! I now have 8 donor keycaps on my 14 month old Magic Keyboard (worn out the print on the caps) and it looks like new :) The trick -- indeed -- for the Magic Keyboard is to pop the bottom, slide down to remove, slide up and push the bottom down to replace. Once you get the hang of it, it's easy as proverbial pie :)
由完成的
添加一条评论
添加你的答案
Michael Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 108
过去 30 天: 415
总计 28,359
