跳转到主内容
加入维修社区 - 创建账户
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
How do I replace a broken upper case cable?
I took my macbook apart to replace the fan and damaged the upper case cable in the process. I bought a new one but I would like to make sure I don't damage anything else replacing it. Can someone please tell me how to remove the upper case cable and install another one? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
I take it your talking about the keyboard to logic board cable. The keyboard socket is OK? Where did you get just the cable?
完成的
Yes, it is the cable that connects the keyboard and trackpad (and I think the power button) to the logic board. When you ask about the keyboard socket, I assume you are talking about the connector on the logic board that the cable plugs into. As far as I can tell it is fine. There was one pin that broke off the cable, that is the problem. ifixit.com sells the cable and I have already purchased a new one. I just need to know how to remove the old one if anyone has done this before. I don't want to just start prying things up to try to figure it out.
完成的
添加一条评论
1个答案
最有帮助的答案
Ok, i had to pull out a keyboard to see how to do this. Just peal the vinyl tab off the trackpad slowly. You will clearly see the insert on the trackpad for the cable right next to the input for the keyboard. It pulls out laterally.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 683
