跳转到主内容
加入维修社区 - 创建账户
2013 年 8 月发布。型号为 Z796C。
Editing my contact information
Hi, I have a ZTE Majesty Pro LTE Z798BL. My service provider is Tracfone/Safelink.
I am attempting to edit my contacts. When I touch the screen, I get a message that says I have disabled required permission. What permission? And how do I re-enable it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
4条评论
I also have this problem and can not find an answer.
完成的
Yes help me remove message
完成的
ZTE, never again. I can't delete numbers I don't want anymore. I hate this Chinese built garbage!
完成的
My phone doesn't allow any contact to save
完成的
添加一条评论
3个答案
最有帮助的答案
go into your setting and enable the permissions for your contacts..should be in application settings
这个答案有帮助吗?
得分 5
4条评论:
there are no permissions under settings, I have the same issue, there are no permissions under the apps either for this.
完成的
I had same problem on new phone and stumbled around for several days. Then happened across this and turned on all permissions in contact applications and the edit now works. Now I have to figure out which permissions I can turn off!
Phil Starr
完成的
Thank you Phil Starr, I turned on 'all permissions' in contacts an was able to edit my mom's ZTE cell. Thanks again!
完成的
How do I find the contact applications so I can all he permissions?
完成的
添加一条评论
These Instructions were given me by a Engineering Student (who will be designing Cell Phones) at Walmart in a Cell Phone Kiosk. It was for the ZTE ZFIVE G
Home, Settings, Apps -
NOT apps as I was doing.
Then scroll down to Contacts…
Permissions then…
Storage - Slide the slider thing to the right.
Hope this helps - (I mentioned to her that non of these instructions were “intuitive” - who would think of it and not mentioned in the booklet either - errr! Please when designing cell phones make it intuitive. MHO
这个答案有帮助吗?
得分 0
添加一条评论
How to restore contacts
Update (09/01/2020)
It did not
Resore contacts
这个答案有帮助吗?
得分 0
1条评论:
On cell majestic. Zte
完成的
添加一条评论
添加你的答案
Elena Vaccaro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 8,169
