跳转到主内容
加入维修社区 - 创建账户
2003 X5 alternator replacement
specific r&r sequence for replacement of alternator. top down? bottom up? items to be removed
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
https://www.youtube.com/watch?v=5-9fVRJg...
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Here are the steps for alternator replacement of BMW X5
  • Remove the drain plug on the driver's side bottom of the radiator
  • Drain the coolant and remove the coolant hoses
  • Loose the belt tensioner
  • Unhook the battery +/- connections
  • Unbolt and remove old alternator
  • Take the wires off the new alternator
  • Clean area where alternator goes, bolt the new alternator inside
  • Reattach coolant hoses and refill system with coolant
  • Put the intake tube and duct back on.
这个答案有帮助吗?
得分 2
添加一条评论
For those who are changing alternator, it is not necessary to remove radiator as most DIY videos will instruct. It is a tight fit, but simply put cardboard protection against your radiator and you can wedge alternator up and out with no damage. It is a tight squeeze, but you can pull it out an put new one in without the extra wasted time pulling radiator out. I always look for short cuts on my vehicles when it comes to repairs.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Dan McGough 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 57
总计 5,866
