跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1366 个问题 查看全部
Now I'm one of those people
Did two handfuls, literally, of iPhone 7 and iPhone 7 plus. Had to do a warranty on a camera. Put the new camera on, and now the home button won't work! Yay! What else doesn't work? The camera! Tried two different displays and an oem one. Sometimes the home button works, most times not. I realize I'm supposed to be the resident iPhone expert, but I threw a bicycle pump across the shop after dealing with this. Any ideas? @mayer @oldturkey03 @refectio @pccheese @gigabit87898 @everybody else I forgot
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Try it without the camera you replaced.
完成的
Isn't an iPhone 7 less than a year old, and hence still covered under Apple Warranty?
完成的
So let me get this straight: You replaced the camera and the camera and home button don't work. Right?
完成的
添加一条评论
1个答案
已选择的解决方案
When I run into frustrations like this, I have learned to walk away from it, go take a nap and let my mind clear. 50% of the time i will wake up and know the answer.
这个答案有帮助吗?
得分 5
11条评论:
better throwing a bike pump rather than the phone. I know ive had the urge to do so. A nap works too
完成的
I told her 24 hours. Tried again this morning. One of the local shops advised me to just give her a refund, and get it out of my shop. Which I did. But I still want to know the answer! Which is difficult cause phone is gone now. Also my neighbor whom advised me said "yeah, we've had that. You can keep tinkering, or get rid of a gigantic headache" What I don't understand is the intermittent action...ya know now that I think about it, the button did work without the camera...
完成的
Also the warranty on the camera, was an issue with the microphone/speaker. Think I hurt it while removing it
完成的
A damaged / defective front camera assembly can cause the home button to stop working.
Especially if you plug it upside down while testing the front camera without installing it fully.
I guess the issue here right now is getting reliable replacement parts for the front camera assembly.
完成的
Telling her 24 hrs was part of the problem. You put a deadline on yourself and additional pressure. I've done the same thing myself. You want to please the customer but it then ends up where you lose and the customer loses.
As Scotty on the Enterprises did, always tell them it is going to take twice as long as you think it is. Then when you finish in half the time, you're a genius instead of an incompetent out of work technician.
完成的
显示更多的6条评论
添加一条评论
添加你的答案
iMedic 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 13
总计 180
