跳转到主内容
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
Why am I gettung error code OxF4?
Epson XP-630 printer
When I turn the power on I hear a whirring sound and get error code OxF4. Says to turn power off then on again. Same thing happens. I`ve checked for paper jams and can`t find any. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
jmicric try this first. Open your printer so that the cartridge housing is accessible then turn your printer off.
Gently slide cartridge housing about halfway to the left, then turn the printer back on. On startup the cartridge housing should move all the way to the right. Once it does that gently push up and back on the housing and gently jiggle the housing as it tries to free itself. The housing should eventually snap back to the left which should stop giving you this error message. It is a bit tricky and may take a lot of attempts.
You could also try to see if you can find the Service adjustment program for this printer which may help to adjust the settings that are off on your printer.
这个答案有帮助吗?
得分 3
添加一条评论
this was not helpful
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jmicric 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,616
