跳转到主内容
加入维修社区 - 创建账户
HP Pavilion dv6500 是一款经济实惠的多媒体笔记本电脑,配备 15.4 英寸屏幕、时尚的外壳以及安全指纹扫描仪。
Display is completely black
When I start my notebook the display is completely black, I have already changed the inverter but the problem isn't resolved.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The problem can be the display, the graphics adapter or the mother board. If you connect an external monitor and it shows your desk top then you have a bad display. If you don't have an external monitor, use a flashlight angled to see if you can see icons on the desktop, this narrows the problem to a back light on the display. If none of these steps work, then you may have a bad mother board or bad graphics adapter. Shut down and remove all the memory and see if you get a beep error, a beep error will indicate that the mother board is working.
这个答案有帮助吗?
得分 1
10条评论:
I must remove RAM ?
由完成的
This is to test to see if the motherboard is good, if you get a beep error then the mother board is good. Still could be problem with graphics adapter that is also on mother board.
由完成的
If mother board is working, how do I identify the problem?
由完成的
I have remove RAM and I listen a beep
由完成的
What do you suggest?
由完成的
显示更多的5条评论
添加一条评论
添加你的答案
Piero Sabino 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 31
总计 778
