跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
How Do I Replace or Clean the audio jack?
When I plug the headphones in, I get static,or a choppy sound as if im sliding the headphone plug thingy in and out. Sometimes the music also gets like, muted. I'm sure there is dust or something in there, but can I get to the headphone jack w/o having to take the whole thing apart? Also, if the little headphone jack part needs to be replaced, how is that done? Can you provide a teardown for that?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Athena try the "air in a can" from your local department or electronic store. you can of course try any other compressed air to blow it out. I would stay away from sticking anything in there. If you need to replace the jack itself, it does get a little trickier. The jack is solder to the logic board. So unless you have a spare and someone who can do that type of soldering, you may have to replace the board. Here are the instruction iPod Touch 1st Generation Logic Board Replacement and good luck to you. Oh yeah, try a different set of headphones to just to make sure it is the jack.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Athena Strong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 2,093
