跳转到主内容
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
How to remove a stripped screw?
Does anyone have any suggestions for a completely stripped screw?
My op1 got run over by a truck (no joke) and although it works it's all mangled. I'm trying to take everything out so I can hammer the case back to the right shape. Because of the mangledness one of the screws just would not come out, and now it's stripped. I've tried the rubber band trick, as well as setting the head of a screwdriver with super glue. Neither has worked.
Does anyone have any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Anon,
sorry to hear about your damaged OP-1. You may think about sending TE pictures of it and that it still works. might be good promotion and maybe they can help you with some spare parts or screws.
Getting a stripped screw out is a difficult mission. You probably found this technique page and tried some methods (rubber band, super glue like you mentioned):
如何卸下滑丝的螺丝
I guess its one of the screws right on the keyboard. Those are countersunk head screws and you can't get a grip on them. Also you won't be able to cut them with a rotary tool. So eventually you probably need to drill it out by using a drill bit slightly smaller than the screw and get at least the head off.
I hope you will be able to get the OP-1 back in shape. Crossing fingers for you.
这个答案有帮助吗?
得分 1
1条评论:
添加一条评论
添加你的答案
Anon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 350
