跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Loudspeaker doesn't work after replacing battery
Hi there, I can't find any fix to my problem anywhere, so I decided to ask here:
I've purchased a new battery from this site, replaced the old one and everything works... except for the loudspeaker. I bought another loudspeaker (original) and replaced the old one, but no luck.
Could you help me?
Thank you =)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Did you follow this guide exactly?
There is really no reason for there to be any impact on the speaker. So here are some things to check:
  • If you pried the battery (instead of the pull tabs), double check the dock connector and the surrounding passive components (they are tiny, use magnification). You may have dislodged some components or damaged the connector. Should this be the case, it will require a micro-soldering repair and is not DIY.
  • Also check the contact points under the speaker and on the Dock flex. Clean them with IPA (alcohol).
这个答案有帮助吗?
得分 2
1条评论:
Could it be a damaged connector even though everything else does work?
I did follow this guide, yes.
完成的
添加一条评论
@monsieurdaz, Anthony, Check all phone audio settings and be sure volume is up and not muted. You can try a reset,hold the power and home button for 20 seconds, or until the screen goes black and the Apple logo reappears. No go look in ear phone jack for dust/debri and pick/blow it out, plug in head phone(in and out) a bunch of times to see if internal contact sticking. Recheck the connection for speaker/head phone jack and make sure wires/cable damage and pins are not bent. 1st link is to a detailed article on your iPhones issue with trouble shooting tips and advice.
https://www.payetteforward.com/iphone-sp...
iPhone 5s Lightning Connector and Headphone Jack
iPhone 5s Lightning Connector and Headphone Jack图片
产品
$24.99
这个答案有帮助吗?
得分 2
2条评论:
Volume is up, headphones work, no dust, Bluetooth disabled, the hard reset didn't solve anyhing... =/
The lightning/headphone jack connector DOES however look bad, so that could be the problem... but everything else works, so I'm not 100% sure.
完成的
@monsieurdaz, Anthony, if looks bad, you should change it, link below should help. Good luck with your 5S.
iPhone 5s Lightning连接口更换
完成的
添加一条评论
添加你的答案
Anthony Michalyk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 991
