跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
iPod classic 5th generation
damaged one of the 2 wires not the hard drive wire
were can i find replacement wire /
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@bdocast1953 it would help if you give as a bit more information. The only other "wires" would be your hold switch/audio jack wire, the display cable , or the battery wire. For the battery wire, you will have to replace the battery. If it is the display cable, you will need a new LCD and for the audio jack you will need a new one of those. You also need to know if it is a 30GB or the thicker 60/80GB model. Headphone Jack/Hold switch iPod 5th Gen display iPod 5th Gen Battery and use these guides for the repair. If unsure, post some images of the broken "wires" with your question. Use this guide for that.
Replace a broken or damaged color display for your iPod Video with this part.图片
产品
iPod Video Color Display
$29.99
Includes headphone jack & hold switch图片
产品
iPod Video 60/80 GB Headphone Jack & Hold Switch
$24.99
Replace a compatible with an iPod Video 30 GB. Model #616-0229. 580 mAh.图片
产品
iPod Video 30 GB Battery
$13.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
herbert castro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 237
