跳转到主内容
加入维修社区 - 创建账户
DualShock 4 CHU-ZCT2U 的维修指南、手册和故障排除帮助。获取自己维修 DualShock 4 CHU-ZCT2U 所需的一切。
L2 trigger wrong input
Hello, I have the following problem.
When I press the L2 button, the analog is apparently triggered up.
If I move the left analogue and press L2 again, the problem disappears, but on some drives it returns.
What could be the problem? What do they suggest?
Here's a video of the problem: https://youtu.be/u6hUOQScQnw
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
I got a controller that was doing that issue and I found a permanent fix to this problem. If resetting the controller does not work, the problem is related to the joystick (joystick drift). Sometimes it will just need a clean to the potentiometer and other times, you will need to change it but they are very cheap and easy to change (no soldering require). I found this video that should help you to fix your issue : https://youtu.be/RcIza5Zz8qY
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Henrique Sameshima 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 888
