跳转到主内容
加入维修社区 - 创建账户
iRobot Roomba 655 Pet Series 扫地机器人,于 2012 年制造。Costco 专供型号。
Side brush isn't working.
The side brush isn't working anymore. I've replaced the entire side brush unit and it will do a .25 revolution once it starts cleaning then the side brush will not work. I've striped it down and cleaned everything that could be cleaned. I am At a loss here no idea what's up and I-robot told me to buy a new one when I called the help line.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you solved the problem? I have the exact same thing, replaced the module, still not spinning :-(
由完成的
添加一条评论
1个答案
已选择的解决方案
@bobo006, Ben, If you have already replaced the side brush motor and still not working, check the wires and connector for being, loose/damaged/corroded/check the connector with DVOM to ensure power is getting to the motor and make necessary repairs if defect found. If motor has not been replaced perhaps consider replacing motor. 1st link below is a guide to replacing side brush motor and 2nd link will get you inside to inspect the mother board for loose/damaged/burnt components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iRobot Roomba 655 宠物系列边刷电机更换
iRobot Roomba 655 Pet Series 主板更换
iRobot Roomba 655 Pet Series 主板图片
指南
难度:
困难
2 - 3 hours
iRobot Roomba 655 Pet Series 边刷电机图片
指南
难度:
中等
10 - 15 minutes
这个答案有帮助吗?
得分 2
2条评论:
My roomba side brush remains on. This happened after my roomba got wet. What can I do?
由完成的
Be sure the central screw on the brush is not too tight. Even though you can turn it with your fingers Roomba will detect a TANGLE if its too tight and shut it down.
由完成的
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 4,374
