跳转到主内容
The McCulloch MC1275 is a heavy-duty canister steam cleaner that uses ordinary water heated to over 200 degrees Fahrenheit to clean and sanitize a wide variety of surfaces.
28 个问题 查看全部
My steamer wont make steam
Whenever I press the steaming button, rather than steam, only water will come out in short drips. The device is plugged in, the indicator light is on, etc. We even followed the manual for setup to the letter and haven't poked around inside the machine at all. This machine is new, (Only a few hours old)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
nate michael, If you have followed all the correct operating/setup procedures in the manual(link below), the heating element may be defective. Since the steamer is so new return to place of purchase for replacement /refund. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/466149...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
nate michael 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 41
总计 3,956
