8 Blink red LED for th-p50ut50a
Hi there.
I have a Panasonic Viera TH-P50UT50A (May 2012) and when you turn it on the green LED at the front flashes for a short amount of time and then get 8 blinks from the RED LED on the front of the TV.
I opened the back of the TV & started to isolate the problem PCBs. If i disconnect the (looking at the back of the tv with the cover off) Left hand PCB from the two 'pinkish' wires I get 7 RED blinks on the front of the TV when its turned on. Plug this back in and it returns to 8 blinks.
I disconnected the two pinkish wires going to the board on the right (pinkish wires leads to/from the main power board) and it still has 8 blinks. I found if I disconnected the white ribbon cable on the bottom of the Right hand PCB that leads to the AV input board the TV LED on the front will remain Green & no blinks occur.
Any advice which PCB could be at fault & where can I get some parts for this?
Thanks in advance.
1条评论
hello i am having the same problem but the opposite, when i turn on the tv i have 7 blink code and when i detach the SE board i get the 8 blink code.
由 dzhan apti 完成的
