跳转到主内容
加入维修社区 - 创建账户
这是一款与 Wii U 游戏主机配套的触摸屏控制器。它于 2012 年 11 月 18 日发布,有黑色和白色可选。型号:WUP-010 (USA)
region lock location on the motherboard
Hello ifixit community,
here is my problem;
I have a working motherboard with the wrong region and another one with a broken DRC-WUP graphic chip with the right region. I just want to solder the chip where the region lock is located to the working motherboard.
can someone tell me, where the region lock is located on the wii u gamepad motherboard?
Thanks for helping,
rgds Thomas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
I can’t confirm that.. I bought USA region mother board and took that chip from old board. Still wrong region gamepad. But.. I can’t be 100% sure that broken motherboard was EU region like my test console.
这个答案有帮助吗?
得分 1
添加一条评论
I found it out mysef. You just have to replace the U10 Micron 25Q256A 256 Mb Serial Flash with your original. Then you can use a motherboard with different region
这个答案有帮助吗?
得分 0
1条评论:
This is not a permanent fix and the gamepad will only work with the Wii U console that the old Gamepad was paired with. This might be fine in the short term, but if anything forces you to re-pair the gamepad you will be out of luck. On that note, if you try and pair the gamepad to another Wii U, it will fail with error code "165-9901"
"The update cannot be completed using a Wii U GamePad designed for a different region."
完成的
添加一条评论
Hi! You're gamepad is working??
这个答案有帮助吗?
得分 0
添加一条评论
after installing the new motherboard, follow wiiu.hacks.guide to install aroma cfw and this will allow you to bypass the region lock via software
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hannah Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 3,535
