跳转到主内容
加入维修社区 - 创建账户
Dell XPS 14 L421X 发布于 2012 年夏季,配备第三代 Intel Core 处理器、Nvidia 显卡以及分辨率为 1600x900 像素的 14 英寸屏幕。
Computer not bringing me to login screen
Hello, I have recently been using a Dell Laptop and It has had no problems since I got it. When I was using it, it shut down on its own, and when I turned it back on, it brought me to a weird looking white screen with an error message, and it scans for an issue, but when it is scanning, it shuts off on its own and doesn't turn on again. When I turned it back on, I ran a Diagnostic test to see what the problem was, and it turned my screen into a bunch of lines that were different colors, and shortly after, it asked me if I saw all different colors, and I answered yes. It then started to scan for the issue, then started to beep really loudly every 4-5 seconds, and it beeped about 3 times before I closed the computer because the beeping was super loud and obnoxious. I sent it to the Dell company to figure out what the problem was, and it went on a little trip back and forth to get fixed, and it turns out there was something wrong with the hard drive, and once we got it back, it was working fine. However, a few days after I started using it again, it went went back to this issue.
I don't want to send this laptop back to the Dell company and pay even more money to get it fixed AGAIN and have it break again, and have to do this process once again.
Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There should be a warranty for the repair done, if it is the same problem. The beep noise you heard during diagnostics was either a sound test or a diagnostic step failed, in which case you should have gotten an error message on the screen. Since it was repaired by Dell recently, call their tech support and tell them that the problem has reoccurred. The repair warranty should be about 90 days.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ethan Cahill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 401
