跳转到主内容
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530 个问题 查看全部
I want to fix my own logic board
I'm getting a question mark folder and the repair shop said I need the costly new logic board repair job. It would cost more than another laptop. I hate to just toss it. Has a new hard drive! Can I fix it myself and, if so, where can I find a good diagram of which part is the logic board when I open the case up? Also, I need specific layperson descriptions of the points I need to repair. I can do anything with instruction -- help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi! From the symptoms you've described, it sounds possible that the hard drive is dead, or that the hard drive is fine and just needs the operating system installed on it. It may in fact be that the motherboard is bad, but that is not evident from what you have described...are there other symptoms (freezing, video problems, etc.)?
If you have the system restore DVD, it's well worth trying to reinstall the operating system by putting the DVD in the drive, and then powering up holding down the "C" key to boot from it, and then following the prompts to reinstall the OS.
I wouldn't recommend trying to repair an iBook motherboard. They are generally not repairable once they start to go bad, and it is not practical or easy to do. Even Apple doesn't repair logic boards -- they just replace them.
这个答案有帮助吗?
得分 2
1条评论:
I agree. Logic boards are frequently multi-layered boards, so there may be a problem that you can't even see, let alone fix.
完成的
添加一条评论
It is unclear what you mean by "Can I fix it?".
"Is the actual problem with this iBook G4 something that can be fixed by replacing hardware?"
Maybe.
Most of the time, people who see this particular symptom -- a blinking question mark folder -- have perfectly functional hardware.
If you are lucky, you are one of those people.
If so, you can fix the real problem, that gives this particular symptom, without any hardware modifications.
Have you tried the ways of fixing this particular symptom described at:
If the real problem is one of the above software issues, then replacing perfectly good hardware isn't going to help.
If none of these fixes work for you, then it is almost certain that yes, it is a hardware problem that can be fixed by replacing hardware.
"Is the actual problem with this iBook G4 something that can be fixed by replacing the logic board?"
Maybe.
There are several pieces of hardware that, should they fail, would cause this symptom:
  • bad hard drive cable
  • good hard drive cable, but somehow it has come loose and needs to be firmly plugged back in.
  • bad hard drive -- Is it possible that maybe your "new" hard drive is a dud and never did work?
  • bad logic board
If the real problem is in some hardware other than the logic board, then replacing a perfectly good logic board isn't going to help.
"Can I fix iBook logic board by replacing or adjusting parts on that logic board?"
Not in any cost effective method.
There exist people with the manual dexterity and electronics test bench equipment and soldering rework station equipment to do that.
But there are far more valuable things they could be working on.
It's far more cost effective to discard the bad logic board and replace it with a good one.
"Can I fix an iBook G4 by replacing the logic board?"
Yes, if the problem is in fact the logic board, there are some excellent diagrams at
iBook G4
describing how to get at the logic board, and
Josh Calvetti Possible to Swap Logic Boards?
says he was able to fix an iBook G4 by replacing the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Beth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 2,981
