跳转到主内容
加入维修社区 - 创建账户
为各种电视(TV)品牌和样式提供指南和支持。
Why Is My Screen Flipped?
My Sharp Aquos smart tv (Model LC-55LE653U) has a flipped image (Upside Down). I can't find the flip feature on this model Is there a Service Mode to bring it back?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
5条评论
Hi there. I have bush led smart TV the picture is upside down. I got up service menu but there is no mirror or flip options can you help me to get the picture back to normal in the right direction. Cheers
完成的
@James skett ,
What is the model number of the TV?
完成的
Hi there I'm an electronics engineer, my flat screen TV VESTEL MODEL NO:VES315 WNDL-01, PICTURE UPSIDE DOWN BUT NO FLIPor MIRROR option. Pls how can I get the picture back to normal?
完成的
My tv has same problems but code dont work
完成的
My tv screen is opposite
完成的
添加一条评论
4个答案
已选择的解决方案
@repairking there should be a setting on your TV that is called Picture Flip. See if you can access it with your Sharp remote (not a Universal remote)
Press MENU
Scroll left or right to SETUP
Scroll up or down to PICTURE FLIP
Scroll up or down to STANDARD
Press ENTER
Press MENU
That should turn your picture normal. Let us know if it worked.
这个答案有帮助吗?
得分 7
10条评论:
Didn't work there is no picture flip on my TV
完成的
Didn’t work no picture flip on my tv
完成的
dawngledhill paula.johnston456 if you are having a Sharp TV you will need the original remote.. How did you try it?
完成的
Hi @ paula.johnston456 @ dawngledhill,
If it happened after a recent update here's a link to an answer that may be of some help.
Sharp aquos LC-32CHG6021K TV
完成的
This works ...go to menu then quickly press 11 47, select item 7 on the panel...then item 9 ..brilliant
完成的
显示更多的5条评论
添加一条评论
This worked for me.
Sharp lcd colour TV Model 32BB41
MENU straight after press 11471147
Scroll down to PANEL SETTING
Press mirror
这个答案有帮助吗?
得分 3
1条评论:
I have replaced Nutec board in a Samsung plasma ,showing upside down pictures.
Pressing menue n 1147 shows factory setting without control pannel on the list.
Any one to help
完成的
添加一条评论
We had an upside down picture after a brief power blip. I unplugged the TV, waited for about 20 seconds then plugged it back in. That fixed it.
这个答案有帮助吗?
得分 0
添加一条评论
Try cntl/alt/uparrow that might fix it.
这个答案有帮助吗?
得分 0
2条评论:
@acdm on a computer maybe but not on a TV. Consider editing your answer since it is definitely not working.
完成的
Yes, I got that wrong ! Realised as I hit the post button- Sorry
完成的
添加一条评论
添加你的答案
Danny Hannah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 62
总计 37,362
