跳转到主内容
加入维修社区 - 创建账户
Asus X551M-RLN03 是 Asus X 系列的一款机型。它是一款 15.6 英寸的笔记本电脑,运行 Windows 8 系统,搭载 Intel Core 处理器。
Will not turn on
The laptop was working and lid was closed. Upon reopening the unit will not power back on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
First make sure the power supply is good and the battery is charged?
If those are OK, try this...
Unplug the power supply and also remove the battery.
With both sources of power removed , now press the power button a few times
Then reinsert battery , power supply & try again.
If that doesn't work, I would ask you this....
You said the " laptop was working and lid was closed".
Meaning, the computer was running and when you returned it ws off & then unable to power back on?
If yes,.... was it laying on something like your bed , sofa, etc....?
If yes, ..... then the air vent for the fan may have been blocked, causing it to overheat.
这个答案有帮助吗?
得分 0
1条评论:
Check to make sure the led light is on. If so PLug in a USB monitor or to a tv make to see if video is there. I have same problem and it's the video problem
Either video card or display (monitor) it play beautiful on tv. Still trouble shooting loading new version of windows to see if its drivers problem they might not be correct. My screen lite up for a second the other day.After taking apart and removing battery and doing 30 second power button to get rid of residual battery juice it lite for 30 seconds. So on to more trouble shooting. Leave notes on next results ...
由完成的
添加一条评论
try to clean ram or replace it .if dose not work maybe there is problem in mother board like power ram ic or VGA card or some wet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gregsgirl1966 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 19
总计 492
