跳转到主内容
加入维修社区 - 创建账户
如果知道方法,我们可以做的事情太多了。此专区旨在汇集完成某些特定维修所需的各种专业技能。
What is the best way to dry used desiccant Silica-Gel?
I like to keep gadgets together with the accessories - an ideal way to store is a ziploc bag. Condensation is a worry with all electronics - therefore I want to use the small bags of desiccant that come with all sort of things.
What is the best way to dry these / restore them before use?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I have a larger commercial product that I keep in my Camara Case. It has printed on its Case "Reactivate 3 hours at 300 F". Mine is about 4" x 2" x 1/2".
由完成的
添加一条评论
7个答案
已选择的解决方案
Let the packets bake on a cookie sheet in your oven at 150 degrees for 12-18 minutes or so. Allow them to cool and they should be ready to go. Alternatively, you can find new ones on the internet for a relatively low cost.
这个答案有帮助吗?
得分 13
4条评论:
I accepted this answer as it attracted a score of 3 - meaning to me others think too this is the may to go. Thank You
由完成的
Put the containers you intend to store the gel in the oven with the gel (air tight ones). Unless your camera equipment is in airtight containers the gel won't be effective for more than a short time, so you would have to change them regularly, as they will draw moisture from the wider area and become useless quickly
由完成的
I know it's been a while but did you mean 150 degrees Fahrenheit or Celsius?
由完成的
@clancyclawson it's 150°C also, importantly, this the maximum temperature it can tolerate. It may be a lot safer to aim for 120°C and leave it for a little longer, like up to 3 hours. Because once it burns, it's done.
You can weigh the pellets before, and after they cool down, to calculate how much water they have shed in the process. Expect the final measure to be around 2/3 of the initial measure. (ie: if 120g before, and gel is saturated with water, expect to see 80g after baking) Naturally, your results may differ.
由完成的
添加一条评论
dry in a food dehydrator 120 f or 50 c for 2 or more hours i do this with color changing this works good
这个答案有帮助吗?
得分 3
4条评论:
Awesome... This info was really helpful. You should get more up-votes for this, definitely!
由完成的
From what I've read, the colour changing type of silica packs should not be used anywhere near food items as they contain cobalt chloride, so unless you don't use your food dehydrator or oven for food, I wouldn't recommend those at all.
由完成的
Don't know what is in them but I'm pretty sure they can be used in food and medication. Link to a Mfr website of one that was in an orc supplement: https://www.multisorb.com/desiccants/des...
由完成的
I put the slilca in a glass bowl and microwave for 2 min. If you use the silica that is blue when dry and pink when hydrated it is easy to get a handle on how long to heat. Cool the glass bowl in a tightly covered container. An old coffee can with plastic lid is ideal!
由完成的
添加一条评论
Just leave them a day in the sun, it will do.
这个答案有帮助吗?
得分 1
1条评论:
Actually, that depends on where you live. If you're in a very low humidity area, might work. In Florida? Forget it!
由完成的
添加一条评论
IF it is a color changing Silica Gel, it can be reheated to 248 degrees Farenheit or 120 degrees Celsius to reset the colour change. As soon as the color has reverted, it can be re-used.
这个答案有帮助吗?
得分 1
添加一条评论
leave it in the sun ...
some say put in oven or microwave, but limited tries...
perhaps for long term, can consider a dry box.
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
silica gels adsorb moisture, so simply drying them under sun is simple technique...
这个答案有帮助吗?
得分 -1
3条评论:
If you liked miguel answer just vote it up, don't repeat it.
由完成的
well, if u see it repeated, then you got better lots of time to see who repeats others, keep going.
由完成的
由完成的
添加一条评论
添加你的答案
Spikey2 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 73
过去 30 天: 229
All Time: 61,032
