跳转到主内容
Repair information and guides for saws, including circular saws, jigsaws, and scroller saws.
77 个问题 查看全部
Why is it losing power? Where to buy parts?
Craftsman Model 315.172110 jig saw, it's losing power. I ASSUME the brushes need to be replaced. Not having much luck finding replacement brushes online. Anyone know, first, if this is the issue and second, where I can find a brush kit?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Dan Krier describe the "it's losing power" situation a bit better. If the brushes are worn then the jigsaw will not work. Not working means absolutely nothing working.
完成的
添加一条评论
1个答案
已选择的解决方案
Dan Krier, I had the same result as you after doing a good search brushes discontinued and no alternative part listed. If need be, in the past I was able to order similar brush to what I required in a old saw(new brush was a little wider) so all I did was sand it down a bit to fit, reused old holder/spring and it worked very well. Below is a sample of brushes that are available for power tools. etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.amazon.ca/s/?ie=UTF8&keyword...
http://ohiocarbon.com/products/power-too...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Dan Krier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 91
