跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Front facing camera replacement
Hi there
I need to replace the front mic of an iphone 6s plus. I suppose that I need to replace the camera and everything at the same time. Would the camera form iPhone 6s work?
This one here: iPhone 6s Front Camera and Sensor Cable
regards
Frímann
Replace a front camera and sensor cable assembly compatible with the iPhone 6s. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00123-01.图片
产品
$22.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
laukur, Directly from your link in your question. Compatibility of iPhone 6s Front Camera and Sensor Cable, Item code: IF314-015-3 for All iPhone 6s , ((Not iPhone 6, 6 Plus, or 6s Plus)).
As far as having to replace the camera because you need to replace a bad mic. which is part of the lightning assy., camera should not have to be replaced unless defective.
Lightning Connector Part Assembly includes:
Lightning connector
Dual microphones
Headphone jack
Links below are for replacement part and guide for installation of the Lightning Connector Assy..
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iPhone 6s Plus Lightning Connector and Headphone Jack
iPhone 6s Plus Lightning 接口和耳机插口
Replace a battery compatible with iPhone 6s Plus Models A1634, A1687, A1690, and A1699 smartphones. Part #821-00126-A.图片
产品
$24.99
这个答案有帮助吗?
得分 1
1条评论:
TL:DR You need to use the 6s plus front replacement camera.
The normal 6S front cam will not work.
完成的
添加一条评论
Hi and thanks for your reply! However I think there is some misunderstanding. It's the front mic by the earpiece and close to the front facing camera (facetime camera often called) that is broken. I believe your directions were for the mics at the bottom of the phone (by the headphone jack)
Regards
Frimann
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
laukur 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 157
