How can I upgrade storage?
I have a Lenovo 100S Chromebook, serial number LR04HMFR if you need it, and I was wondering if I could, how would I go about upgrading my 16G storage to something like 120G.
The hard drive for this device is actually soldered directly onto the motherboard. Unless you are very skilled with a soldering iron, it will not be easy to remove. I highly suggest simply just investing in an external hard drive if you are looking for more memory to store your files.
这个答案有帮助吗?
step 1 undo the screw on the back
Step 2 gently remove the hard drive (it is silver)
Step 3 Unplug the cable from the hard drive
Step 4 put new hard drive in a reconnect cable
step5 put screw back in
step 6 you're done
这个答案有帮助吗?
No, impossible on this model, the memory is a chip soldered to the mainboard.
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 1,737
