跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
798 个问题 查看全部
The Brown cable hold down breaks when you remove it.
The brown connector breaks as soon as you pull it straight out to take the wire out in step 3. It has two little arms with hooks and one arm is now gone. How do I reassemble my ipod (reverse step 3) since you didn't supply a new brown connector with the new cable? This should come with the cable assemble.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I can tell you of hand without exactly knowing which cable or part on the iPod video you replaced, that none of the cables or parts come with replacement clips. All the connectors have PERMANENT clips that push on the cable and thus cause the connection. You can try to find a clip from another logic board of same kind and see if you can replace it. This is very tedious and will require some good magnification and dexterity. Personally I think you may have to replace the logic board. But give us some more info and we will see if we can help you further. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joseph Hart 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 469
