跳转到主内容
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 个问题 查看全部
问题已关闭
Why is my acer staying on the windows xp screen?
When turned on today My Acer ZG5 loaded, showed the first two screens and stopped on the multi colored screen that says Windows Xp.The start menu never came up. I have some very important pictures on here that cannot be replaced.Can you guide me in what to do? Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You can try to start in safe mode. when your computer restarts immediately after the bios/postcheck hit f8 that should bring up a menu where you can selct how to start windows.select safe Mode and that should start windwos. Ince it has started up you can check under the device manager if there are any items that show as non functioning or not recognized. It does sound like a system file error and could be resolved if you restore to an earlier date. http://support.microsoft.com/kb/306084 shows you how to do that. good luck and let us now if this helped ...
这个答案有帮助吗?
得分 1
添加一条评论
If oldturkeys solution does not work for you consider obtaining a external case for the hard drive. Remove your HD and install it in the case and hook to another computer to transfer your photos. I keep my photos on four different drives just in case--you might want to consider keeping yours in at least two places. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 442
