Crazy Drive train issues ...
What would cause my drive to fall off as I'm driving 55mph down a high way .????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@hairs,Montell, More info. may give a better answer, what exactly happen, did the drive shaft break, did the transmission pop out of gear, did the transmission start slipping and you lost all gears? Help us to answer your question by being a little more descriptive. If it was your drive shaft that broke and fell off, normally caused by a faulty/dry(no lube),bad universal joint or loose/broken universal retainer/bolts.
由完成的
添加一条评论
