跳转到主内容
加入维修社区 - 创建账户
一款由 Beats by Dr. Dre 于 2013 年推出的便携式无线蓝牙音箱。
Flashed Beats Pill Plus
My company was recently throwing away a Beats Pill+ that has been "flashed". They told me I could have the speaker if I wanted because it was going in the trash anyway. The flashed Pill has been reprogrammed to only work with an aux cable and when it is plugged in. The Bluetooth and charging capabilities have been disabled. This was done in case someone stole it during our expo they wouldn't be able to sell it. Is there anyway for this "flashed" Pill+ to be reverted back to factory settings? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Nah the factory reset didn't work. I think is was programmed either from Apple or Beats to not be that easy to revert back to the factory settings.
由完成的 分享
Same problem did anyone else get any suggestions please update
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
So there is, however I'm wondering if the settings it was originally on was a display mode, which will likely be unuseable to anyone besides the retailer. Here, try this first, then come back to us
Use the Lightning to USB cable to plug your Beats Pill+ into a power source.
Turn the speaker on.
Hold down both the "b" button and the power button for 6 seconds.
The Fuel Gauge flashes red 6 times.
Your Beats Pill+ is restored to the settings it had when it was purchased.
这个答案有帮助吗?
得分 4
3条评论:
由完成的 分享
Correct my guess is that the factory settings are set up for display. So no one can steal it. It can be erased/reset but you'll likely need some code, from the supplier
由完成的 分享
Does the answer to reprogramming it involve coding or wiring?
由完成的 分享
添加一条评论
添加你的答案
Tee Dubs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 55
总计 5,085
