跳转到主内容
加入维修社区 - 创建账户
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
How do I reset phone
How u reseat a zte phone
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@paulinacotton, Paulina, ZTE Zmax Pro Factory Reset Procedure:
From Main Menu go to Settings.
Find Backup and Reset option.
Select Factory Data Reset.
Tap Reset Phone.
Select Erase Everything.
((you will lose all data that has not been backed up))
Links below should help also in resetting your phone. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.hardreset.info/devices/zte/zt...
https://www.youtube.com/watch?v=ssX1ULxV...
http://www.resettoo.com/factory-reset-pr...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Paulina 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 25
总计 218
