跳转到主内容
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
20 个问题 查看全部
Help! Debris stuck in Digital Crown!
Hello iFixit! I need a bit of help here because I cleaned my Apple Watch Sport 2 With a alcohol prep pad, and some of the cloth is now stuck inside the digital crown, making it hard to turn on occasion. My nearest Apple Store is 2 hours away and I have all the tools to DIY it. What should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I would also like if it could be done without opening it as I like my waterproofing seals!
完成的
添加一条评论
2个答案
已选择的解决方案
@reedcrosby,Reed, You may have to get yourself a cheap dollar store magnifier/glasses to aid in seeing if fibers are accessible to dislodge with a small pin/compressed air(should work). If not then you may have to partially disassemble watch to get at debri. Link below shows how to disassemble, if need be. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Apple Watch Series 2拆解
这个答案有帮助吗?
得分 3
3条评论:
Thank you! I never thought of that...
完成的
@reedcrosby, Reed, Welcome, thanks for replying back and good luck with your Apple watch.
完成的
Thanks for the luck, I might need it!
完成的
添加一条评论
Try getting some tweezers and just slowly getting rid of all the fibers, they should eventually come out.
这个答案有帮助吗?
得分 1
1条评论:
I would, but the issue is I cannot see them but I can feel the resistance from them.
完成的
添加一条评论
添加你的答案
Reed Crosby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 3,161
