跳转到主内容
加入维修社区 - 创建账户
2015 年 9 月 25 日发布的 iPhone 6S Plus 的维修信息和指南。型号 A1687, A1634
Touch screen not working after screen replacement
Just replaced the touch screen on a friend's phone, and it's completely unresponsive, LCD works fine though. Old screen is also completely unresponsive with LCD working. Anything I can do to try and fix this or did I bust the connector on the motherboard itself?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
4条评论
I had this problem too after an iPhone 6S Plus screen replacement. I always test “before” I finish assembly and the digitizer was not working. I was holding the screen and the case so they weren’t touching. It turns out that the screen shield needs to be in contact with the case for it to work. That’s 3 hours of diagnostics I’ll never get back.
由完成的
@provibe I’m having the same issue. When I’m holding, it works. When I’m not holding, not working!! I didn’t understand what have you done. Please help me
由完成的
I have the similar issue with Iphone XR. The touch screen doesn't work. I tested it after plugging in the cables, it worked just fine. I turned off the phone, disconnected the cables. Placed the plate over the battery and sim connector and then Plugged back the LCD screen cables and put back its metal plate on it. When I turned on the screen after completing the assembly, the touch screen didn't respond. I have tried disassembly and reassembled a couples time, still doesn't work. Even after the dfu reset, screen doesn't respond.
由完成的
On iphone 8 plus the same story, if you found any solution…?@shanparshan
由完成的
添加一条评论
3个答案
已选择的解决方案
I would closely inspect the connectors for the digitizer on the logic board (look here) as well as the surrounding area for any tiny components that may have been knocked off. Magnification is important here as the parts are tiny.
这个答案有帮助吗?
得分 5
2条评论:
Already looked and didn't see anything, but I don't have any form of magnification with me. Will do again once I get home and have a magnifying glass. If a connector has been knocked off, what's my next course of action? What should I do if I don't see any damage?
由完成的
If the connector or any surrounding components are damaged/missing, it will require a micro-soldering repair.
If you don't see anything with magnification then ideally you need to have this looked at by a repair shop to at least eliminate any modular component (screen, flexes etc) issues. If they can't find anything then a micro-soldering shop should be able to troubleshoot it.
由完成的
添加一条评论
It's most likely the touch filters located blow the connector. https://youtu.be/kk3mYfngY6c
这个答案有帮助吗?
得分 2
添加一条评论
the touch Ic chip seems to be the issue. have come across this issue in my travels, it is a rather quick repair
这个答案有帮助吗?
得分 0
3条评论:
What is the repair??
由完成的
Yeah how do we repair this?
由完成的
Touch screen not working after new complete screen replacement (infinix x5516b) still not working.
由完成的
添加一条评论
添加你的答案
John Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 59
总计 121,307
