跳转到主内容
加入维修社区 - 创建账户
惠普于 2015 年推出的第四代低成本 11.6 英寸 Chromebook 11。
were is the write proctection screw?
i want to turn my school laptop into a regular one but i dont know were the screw is.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
5个答案
最有帮助的答案
The link above is not working, so I attached update photo
https://preview.ibb.co/dxADNH/photo_jpg....
Were is TWO contact pad divided into quarters, but only one has 4 soldering contacts and was covered by screw.
This is applicable for HP Chromebook 11 G4 for US market, version of hardware board DA0Y07MBAF1 rev F
https://ibb.co/mB0r9x
这个答案有帮助吗?
得分 2
添加一条评论
Remove the keyboard by
1) Remove the rubber plugs over the screw access holes. Note that there's one in the top centre of the backing within the product label. It elided me and made me wonder why it was so hard to pry off the keyboard. Luckily I didn't break anything.
2) Remove the screws. There are 9 of them phillips head (I don't know what size, but not overly tiny)
3) Using a plastic pry tool, work around and pry open the gap between the keyboard deck where it nestles into the main body/frame.
4) Carefully lift the keyboard up and to the left. You don't need to disconnect the keyboard to get at the screw, just set it aside.
Image of motherboard with write protect screw bottom right.
5) The write protect screw on mine (HP Chromebook 11 G4) is in the slot on the right with the contact pad divided into quarters. Remove.
Reassemble in reverse of disassembly.
这个答案有帮助吗?
得分 1
3条评论:
is my chromebook supposed to be a white screen after i do this?
由完成的 分享
dude, i had my chromebook shut down and i did what you said, i removed the screw and when i put the keyboard back in my laptop was on and with a white screen. please help
由完成的 分享
Did you disengage the battery cable before you unhooked the keyboard?
由完成的 分享
添加一条评论
A picture is worth a thousand words…
这个答案有帮助吗?
得分 1
添加一条评论
I couldn't find a similar document for the G4 but perhaps the G3 docs referenced below will help? HP is getting more tight with PDF documentation apparently.
Anyone know where the BIOS Write-Protect Screw is on this image?
这个答案有帮助吗?
得分 0
1条评论:
That should work. The G3 and G4 are practically the same from what I've seen.
由完成的 分享
添加一条评论
i cant find write protect screw for hp fortis 14 g11
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keenay Dalton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 140
总计 19,821
